HDD problem
11 Aug 2012
Hi all,
got my new build all set up
motherboard gigabyte ga-z77-d3h
i have my ssd sata 3 into sata port 0
1tb hhd sata 3 into sata port 1
and dvd drive into sata port 2
port 0 and port 1 are both sata 3
port 2-5 are sata 2
the bios is not seeing my 1tb hhd in port 1 but the ssd and dvd drive are working fine. The only time the bios shows my 1tb hdd is on the boot override selection.
Thanks for any advice
sorry its a long time since iv done any builds. not used sata before. if there no difference in speed then ways the point in buying sata3 over sata2?
do the drives have to be set as raid to see them both in the sata3 ports because at the moment there set to ide in bios
thanks
You'll almost certainly want the SATA ports configured as AHCI.
SATA3 makes a difference with SSDs. Traditional HDDs just aren't fast enough for it to matter.
