Citation needed.You need ground pumps in this country, air source are a waste of money
Citation needed.
Ground source are significantly more expensive to install and barely any more efficient these days.
Where they work better is for a ‘district’ heating set up for something like a tower block where the cost of drilling the bore hole can be shared between a number of people. For a single dwelling, not so much, bar a few odd exceptions such as a really large, high end property.
That is the magic bullet, if that 400% can be achieved then problem solved as I already have solar and battery plus solar farm and wind farm investment coming online in the next 6-12 months.air source heat pump should be achieving 350%-400+% across the year
SCOP is not impacted by heat loss or lack of insulation. That is a myth that needs to be debunked. You design the system to the heat loss.
More heat loss = bigger heat pump (or boiler) + bigger rads + bigger bore pipes to enable the required flow rate. Obviously less heat loss is better and that is no different to gas.
More heat loss mean more heat needed from radiators to maintain comfortable home temperature. This can be achieved by running the existing radiator hotter (gas boiler do that 70-80c) or having a bigger radiator with bigger pipe more flow and keeping the radiator flow higher (ASHP 55c). It is the higher water temperature needed which kills the SCOP, just like using ASHP for hot water will achieve lower SCOP.
This is like a catch 22 running the system at 45c and house is freezing will achieve SCOP of 5 , running the system at 70c and house warm will achieve SCOP of 3 and of course this is a over simplified explanation. Heat geek even mention of setting the water tank temperature to 45 which is just above shower temp to make it efficient..... It is not as simple as most would made to believe ASHP is 400% efficient and will safe money and environment or picking the right installer would achieve that, with a house like mine built in the 1930s and a household of 4 it would mean a entire heating system installation plus full installation installation to achieve the efficiency.
The difference is that gas boiler operates at higher temperature of 80/60c and the rest of the radiator system are design to run at that. What we need is a ASHP which can achieve 400% efficiency and just bolt it on the outside wall and connect it to the existing boiler connection and output hot water at 70c![]()
If you've also got alternative heating from wood burning stoves, I'd say that works well with an ASHP. When it's really cold and damp, which is the worst weather for ASHP efficiency due to ice build up on the coils, you can rely on the stoves. For the rest of the year the ASHP will work well.
If you do go for an ASHP make sure you use a reputable installer that does a proper heat loss calculation.
Size the water tank correctly. The water tank can act as a thermal store so I think it's useful to go slightly larger than you would normally especially if you've got solar panels/thermal coupled to the water tank.
I'd also recommend having thermostats and zoning the pipe loops so you can control which areas of the house are heated more and which less.
ASHPs get expensive when you run the flow to rads or UFH at higher temps. Try to keep below 45° C flow temp. Use larger bore pipes (ours are 22mm).
There seems to be same opinion from the weekly same article in sun thats they dont work. Same as the i swapped back from my electric car ones.
If your house is terribly insulated and leaking heat then its going to be hard whatever you get
Unfortunately some houses are so badly insulated that it loose heat faster than you put it in, the only way to heat it faster is the raise the radiator temperature or increase the radiator size and sometime the pipe work. Increase operating temperature will drop the Heat pump efficiency and increase radiator size or pipe size may not always be practical. Most months our normal radiators will function and dare I say anything above 10c outside we will just need a bit of top up heat from the radiators, but heat pump needs to work for us and not we work around it. I think there is already enough discussion in the past few pages to make know that heat pump does not work on its own as boiler replacement, it may require a system change (radiator and pipe) and the right environment (house insulation/heat loss) to make it work to the claims of efficient. One can just plonk it in the boiler location and run it at 60c but it will cost more to run than a gas boiler.I'm fairly confident that heat pumps require a thermal store to work. I don't think you can have one without. But my experience is on the commercial side of things so I guess domestic might be different.
Exactly. The reality is that if you have a poorly performing house, it will just take longer to heat up at lower flow temperatures, which is what heat pumps put out. But that's the same with a highly insulated or a poorly insulated building, just the time taken will be longer in the latter example.
I have an email from Octopus offer of Daikin heat pump install, no details yet as it requires a survey. I will pay 500 refundable deposit and after the survey if goes ahead it will be a Daikin heat pump, water tank and all necessary radiator changes. I will pay £6000 and government grant of £5000. I will likely to go ahead if all the calculation are done correctly and not just sticking a finger in the air and have all my radiator changed if needed to get the go ahead. My gas boiler is 12 years old, radiators are a mix of 12 years old and 30+years old. It will be interesting and happy to update this thread.
I already have 4kw solar and 12kw of battery running on Octopus Go, 1kw co-op wind farm starting hopefully next year and 500w solar co-op starting 2025. Interesting times ahead
