Hi There,
I have been victim of extreme PC lag during working over the past 3 weeks, and I couldnt work out what was causing it.
However after careful diagnostics, I have found out that 1 of my SATA drives (160gig) which is my main work drive, causing the PC to almost grind to a halt whenever the drive is either read from or written to.
I know defragging etc can speed up a drive, but this is immensely slow and I dont think its just a defrag that will solve it.
I have other SATA drives, which are all fine and I dont experience any problems from
Does anyone have any idea why this may be?
Could it be the drive is on its way out?
Any help greatley appreciated
Anyway, that could be the cause of problem/s, because disk is sifting through a lot (files & large disk surface area) to just find a specific file. Also, what I've found, even with only a 20GB partition for Windows is, it gets fragmented quite quickly. Highly suggest you partition your disk - might solve problem but even if, highly recommeded. Acronis Disk Director or Partition Magic can create/merge/resize/etc partitions from Windows without having to reformat (recommend backing up though)
& also he did mention 4 drives
Isn't it a SATA hard disk?
