cleanbluesky said:The only applications i have found for it are...
1) Maintaining absolute maximum speed while taking a corner
I like to get my braking done before the corner. Are you thinking of left foot braking?
Dougsnake said:http://www.runeb.org/www_docs/Jexoticasite/soundandvideo/senna_nsx.avi
watch a master do it (senna R.I.P) in a nsx-r @ suzuka![]()
Zip said:Is there a different program that would play it?
NickXX said:Never worked out why you'd ever need it on normal roads.![]()
Muncher said:The only time you would need it on the roads is if you left your braking very late just before a bend, it will help to settle the car through the bend, but generally it is a track only technique.
