cleanbluesky said:The only applications i have found for it are...
1) Maintaining absolute maximum speed while taking a corner
2) Keeping revs up if you have a car with a autochoke problem
If you take a corner at anything less than max speed you will have time to take your foot off the brake and rev-match shortly after leaving the corner. If you really need to shave that much off, you can rev-match while breaking for the corner - which is where heel to toe comes in...
I have also heard rumour that it is good for certain methods of drifting...
Smiley Man said:no nozzer is right
although in my car its more like big toe on brake little toe on throttle![]()
jimblowscash said:erm no im right, 14 years racing and 9 years instruction at major circuts says i know what im talking about, either that or i have weird feet, wich i dont
ya know, in my first car (micra) i could brake with my heel and blip with my toes. i have smallish feet though and lots of ballet helps with flexabilitymerlin said:Freak tbh. That's totally backwards.
GlasgowTitan said:Senna did it the opposite way in the above video from you jimblow, and I'd be willing to bet he was better at it than you.![]()
did i mention? when i tried it, i ended up in a hedge outside my houseSerj said:I think it would be quite difficult to put the correct amount of pressure on the brake using your heel. There's just not enough feeling or control there imo![]()
Your technique is different to anyone I have seen, no matter how long you have been racing or educating drivers. It is not common to use your heel for the brake and your toe for the throttle and I would go as far as to say you are the only person I have heard of who does it this way, no matter how experienced you feel you are. If you are talking about sliding your right foot then that is different, but to pivot using only your heel on the brake and your toes on the throttle is at odds with published and commonly practiced techniques, a simple search in Google will probably demonstrate this.jimblowscash said:erm no im right, 14 years racing and 9 years instruction at major circuts says i know what im talking about, either that or i have weird feet, wich i dont
I did wonder...merlin said:Bit of BS me thinks.![]()
merlin said:You and many others![]()
