Hello art work engineers! Prepare the design work!
[FnG]magnolia;29226141 said:
Hello popkids!
Guide track for the final song:
https://soundcloud.com/magnolia-down/anatomy-v1
I'm certain soundcloud downmix or apply some kind of compression before you hear what you're supposed to hear but there we are ~shrug~
I should have 4 songs finished with vocals, mixed and mastered by end of March.
That snare is going to get on people's nerves. It sounds harsh, which is good for emphasis but through a 3 minute song on repeat that's going to hurt.
Listening on headphones.
Some william orbit / Bjork influence there too!
It's going to be a 6 minute song and I take your point but it's a 14x6.5' Ludwig Supraphonic with some OH, low wet in the mix, so that's kind of the point :)
Hey buddy :)
Drums could do with more compression i reckon. They sound overly loud and harsh.
I like the start of the track though (the ethereal string bit)
I was going for a Motown thing (see snare reference above) but I don't think it's working for anyone but me. I went light on the kick. What do you think?
Are you a black man?? I'm so confused, did you sing those vocals?
I don't know how to respond to this.
e: thanks for the feedback all :)
Well I listened to one of your songs, and you're singing like a black guy from the 70s...is that you singing?? And just so I don't loook utterly racist, you can normally tell whether a singer is black or not - black people often have a dramatically different tone.
[FnG]magnolia;29226512 said:
New e.p. title right there, if you don't mind?
go for it, however if its published and sold i expect at least one picture of you pulling a stupid face at a traffic warden, within 3 feet of him clearly showing both of your faces.
your normal face does not count...
Got bored, so use or ignore :D
Soundcloud header :
Full Image ;
Larger ;
Good effort, love the intro on Anatomy v1, but "Keep The Lights On v2" is i'm sure unintentional yet blatant mimic of verse from "Somewhere Only We Know" by Kean. Try it - tudum tudum, base line, "I walked across an empty land, I knew the path like the back of my hand", once you hear it, you can't unhear it.
A small tip - don't "master at zero" - don't let you mix go all the way to 0dB at any point, keep it at -1dB peak. Not just because of the whole "wall of sound" malarky, but the main reason is that lossy encoding methods on youtubes, soundclouds, vimeos etc are not precise enough to cope with fractal subtleties of something mixed this close to clipping - in effect the encoding will clip it and will clip it bad. Record is at -1dB, then export it as high quality and bitrate as submission spec allows adjusting peak volume to -0.3dB and submit that to online services.
All sound good through half-decent phones and external Dac+Amp
Pumpkin has a Radiohead feel to it (which is a good thing imo :D )
Free to use, or ignore :
