- 24 Mar 2004
- Blackpool, England
Hi All
Currently trying to fit a Tagan 530w Modular into the Lian Li Q08 case, and if i want to fit the HDD cage im not having much luck.
Measured it up and i figure i need a PSU that is less than 15cm deep to give me enough room for the cables and the HDD Cage.
Would anyone be able to recommend something that might fit?
Scott
Scott
