Ok,just been sorting out my water cooling after I bought a panflo 120mm fan which I attached to my rad.
Here
http://forums.overclockers.co.uk/showthread.php?t=17571514
the problem is stupidly I bought the fan with a 3 pin conector (2 wires) and now I can't 7volt it.I am running it off this at the moment
http://www.zalman.co.kr/
on the 5 volt side but it's not spinning the fan up as fast as I would like and hence the temps are actually higher than the fan it replaced
If I could find a way to get it to 7volt things might inprove.
Any ideas please?
Sorry but the link only takes you to home page,need to follow this to get there:
Home > Product > Controller & Connectors > ZM-MC1
Here
Any ideas please?
