Hi guys, I've had my computer for a a little over a month now and i though i may as well give oc'ing a go as apparently its murder to NOT oc your E6300! So i started like it said in the guide by unlocking the FSB thingy, and incrementing by 5 each time.... I have got the CPU so far up to 1.932 Crappy I know but i can't help but think im doing something wrong. I have read that you are supposed to decrease the FSB on your Memory, but how do i do this? every time i increment the FSB by 5 the memory thing goes up (it's @ 690?) How do I go about decreasing this? I haven't changed any of the other options i.e. (PCIE multiplier or something like that?
, as i didn't know if you are supposed to?)
anyway here are 2 screenies from after the oc.....so far, dunno what's wrong with CPU-Z its quite obviously reading the CPU frequency wrong as coretemp shows ??
This is the CPU one
This is the RAM one:
Help a noob
Kiz
, as i didn't know if you are supposed to?)anyway here are 2 screenies from after the oc.....so far, dunno what's wrong with CPU-Z its quite obviously reading the CPU frequency wrong as coretemp shows ??
This is the CPU one
Help a noob
Kiz
). When you start needing to raise the Vcore is when you'll need to get a better cooler.
Just make sure you are giving it the 2.1 volts it is supposed to have.
have you put a good thermal paste e.g. Artic Silver 5?
