... all come with one month warranty as standard, ...
You've got a lot more cover than that with the Sale of Goods Act, car dealers don't like you to know this though.
[TW]Fox;21684617 said:I dont understand why he said it might be from a different manufacturer. Thats just so wrong it's hilarious.
It is potentially not the cars original engine but there are numerous reasons why an engine would be replaced, many not bad ones, especially for another one the same as the factory engine.
The whole engine/gearbox thing might be a non-issue. I presume the engine and gearbox both work fine, and that the charging issue (Which would have been the alternator) is now fixed. Therefore the only fault with the car is the vibration at around 65mph.
This could be as simple as a buckled wheel or a bodge job on the wheel balancing. It could also be worn suspension bushes - none of these are serious or would reasonably result in a rejection of the car under SOGA.
The engine and gearbox both seem to work fine to me, apart from the vibration it drives well. The problem as I see it is when it needs work doing to it in the future. Also the value of the car, personally I think we paid too much for a car that has had that done to its gearbox/engine. Also you've got to consider selling it on, I'm not going to sell it on without making any potential buyer aware, I doubt any of you here would buy a car that had that done to the gearbox.
[TW]Fox;21684781 said:The problem is that none of this amounts to a right to return the car under SOGA. There is nothing wrong with the functionality offered by the engine and gearbox.
I think your mechanic may have put thoughts/given you bad advice and made the situation a whole lot worse. The engine seems to be correct on the face of it, it may have been replaced but you can't be sure right now.
I'd suggest you let the garage you bought it from try to work out the history of the engine change and figure out why the gearbox/engine has been trimmed to fit. I believe they should have notified you (perhaps only if you had asked though, I guess this is where it gets complicated).
Either way, the engine being replaced may not necessarily be sinister. It could even have been replaced under warranty, although this seems unlikely given the workmanship.
With due respect you don't sound the most clued up of people and it seems your mechanic has scared you somewhat. The gearbox/engine is a non issue and I don't understand why it would affect the value
It has the wrong gearbox on it
I think there's potentially ways to argue it. Does the potential new engine/gearbox alter the CO2 emissions, meaning that the car isn't validly registered?[TW]Fox;21684781 said:The problem is that none of this amounts to a right to return the car under SOGA. There is nothing wrong with the functionality offered by the engine and gearbox.
Something's not right as the bits don't fit together. I don't think that's standard, even for Ford[TW]Fox;21685071 said:Do we know this for sure?
It has the wrong gearbox on it.. hence it having bits chipped out of the bellhousing to make it fit. If it's the wrong box, it's likely got the wrong ratios for that engine in that car. That IS a problem.
2nd opinion on the gearbox maybe?
