Help building a HTPC
12 Oct 2011
I am looking at putting together a HTPC, however slightly confused over the components I need to do this as its something I am not too familiar with.
I already have a bog standard PSU.... are the rest of the components what I need and fit together? Any savings would be appreciated - I just need it for watching movies on, spotify etc.
Product Name Qty Price Line Total
Intel Pentium G3430 3.30GHz (Haswell) Socket LGA1150 Processor - Retail Intel Pentium G3430 3.30GHz (Haswell) Socket LGA1150 Processor - Retail £65.99
(£54.99) £65.99
(£54.99)
ASRock B85M-ITX Intel B85 (Socket 1150) DDR3 ITX Motherboard ASRock B85M-ITX Intel B85 (Socket 1150) DDR3 ITX Motherboard £62.99
(£52.49) £62.99
(£52.49)
Western Digital Scorpio Blue 2.5" 750GB 5400RPM SATA 6Gb/s 8MB Cache - OEM (WD7500BPVX) HDD Western Digital Scorpio Blue 2.5" 750GB 5400RPM SATA 6Gb/s 8MB Cache - OEM (WD7500BPVX) HDD £41.99
(£34.99) £41.99
(£34.99)
OcUK Value Blu-ray / DVDRW combi SATA - OEM OcUK Value Blu-ray / DVDRW combi SATA - OEM £39.95
(£33.29) £39.95
(£33.29)
Cooler Master Elite 120 Advanced Mini-ITX Case - Black Cooler Master Elite 120 Advanced Mini-ITX Case - Black £39.95
(£33.29) £39.95
(£33.29)
Corsair 4GB (1x4GB) DDR3 PC3-10666C9 1333MHz 204-Pin SODIMM Module (CMSO4GX3M1A1333C9) Corsair 4GB (1x4GB) DDR3 PC3-10666C9 1333MHz 204-Pin SODIMM Module (CMSO4GX3M1A1333C9) £31.99
(£26.66) £31.99
(£26.66)
Sub Total : £235.71
Shipping cost assumes delivery to UK Mainland with:
UPS Access Point
(This can be changed during checkout) Shipping : £8.00
VAT is being charged at 20.00% VAT : £48.74
Total : £292.45
I'm also looking for a cheap HTPC since my current Acer Revo has started getting pretty hot and sounds like it's about to take off.
This looks like a good spec. However, and please forgive my ignorance as I haven't built a pc for some years now, but aren't all of the above builds missing a power supply which would probably add another £30? And on the one I've quoted, I think the motherboard only has two SATA slots so wouldn't be able to take the two HDDs and the Bluray drive. This is less of an issue for me as I have a NAS so will just stick to the SSD.
