They maybe budget brand but the reviews I have seen are favourable, hence why I am asking here to see if the opinions are the same.
And as I said earlier, I am not looking for ultra sticky tyres, but a good overall tyre that's also good in the wet and doesn't wear too quickly.
Presumably you have 225/40/18 on the GTD? I'd be going for Goodyear F1 Asymmetric 3 (about 90 per corner fitted) on Blackcircles. Spending any less seems to get you a noticeably worse performing tyre for little saving.
Had these on my 6mps and hated them, had no confidence in them at all and they seemed pretty sloppy in the rain.
Back to rainsports and I happily chuck it about again.
I think I'll be sticking with rainsports for a long while unless there's some drastic changes. Cracking value for the money
Rainsports must be in with a shout of beating the Toyo Proxes or Falken FK452 as 'most over rated internet hero tyre ever'
It's a good tyre but it's a midrange tyre not a performance tyre and isn't comparable to uhp tyres.
http://www.tyrereviews.co.uk/Article/2016-Summer-Tyre-Market-Overview-Braking.htm
From personal experience, Toyo Proxies are terrible in the wet :/
Don't buy cheap tyres, they are cheap for a reason. They are also referred to as "ditch finders" for a reason...
Surprised you've managed to go through and replace a set of Eagle A3 already as they've not been out very long! Were they definitely Assymetric 3?
I think the 3 is slightly better in some areas, slightly worse in others, but the difference is negligible.
I found the 2's and 3's both really poor.
