12 Jun 2014 at 23:33 #81 Quartz Quartz Soldato Joined 1 Apr 2014 Posts 21,062 Location Aberdeen Are you getting any beep codes?
13 Jun 2014 at 00:56 #82 azibux1 azibux1 Soldato Joined 11 Oct 2011 Posts 3,335 Location UK Quartz said: Are you getting any beep codes? Click to expand... See his previous posts, he doesn't have a motherboard speaker to plug in
13 Jun 2014 at 09:30 #83 hogan1 hogan1 Associate Joined 26 Oct 2010 Posts 52 Sounds to me like it could be a cpu issue. Bent pins or maybe your bios needs to be updated in order to work with the cpu.
14 Jun 2014 at 15:42 #84 azibux1 azibux1 Soldato Joined 11 Oct 2011 Posts 3,335 Location UK As above, someone had this issue just the other day http://forums.overclockers.co.uk/showpost.php?p=26450482&postcount=9
