- 17 Apr 2011
- In front of my monitor
Stolen from another forum but may help you:-
UN-plug the power supply from the wall........... (or turn off with the switch on the back of the supply)
Then WAIT until the GREEN LED on the motherboard goes Off.....
STEP #1 : Now...
- remove ALL the RAM sticks
- remove all SATA cable completely from the system (yup pull 'em out and set them across the room...)
- unplug all the hard drives, DVD drives, and floppy(hey ya might have one...
) from the power supply
- unplug all fans from the motherboard
- unplug the 4+4-Pin ATX 12V from the CPU, yes, unplug it too
- unplug all the front panel switches
- unplug all front panel USB cables
- unplug the front panel audio cable
- unplug your mouse, keyboard, or any thing else you have connected to a USB port
There should be no wires, cables, or devices of ANY kind connected to the motherboard...............
The ONLY cable from the power supply that should be connected to ANYTHING is;
- the 24 pin cable to the motherboard
Turn the supply back on....
If the GREEN LED on the motherboard still blinks:
- its the CPU
- or the motherboard
- or the power supply
STEP #2 (If the GREEN LED on the motherboard still blinks)
Next step would be remove the power supply and motherboard from the case. Set them on a non-conductive surface, like card board. Connect just the 24 pin cable again. See if the LED blinks when the supply is turned on. (some times the metal stand off's or the screws holding down the motherboard to those stand off's cause a short circuit. Sitting out side the case on card board we've eliminated that possibility)
STEP #3 (If the GREEN LED on the motherboard still blinks)
Remove the CPU from the motherboard....
Turn on the power
STEP # 4 (If the GREEN LED on the motherboard still blinks)
The motherboard is bad....
Or, you just have a bad power supply
The GREEN LED is powered by the 5 VSB power. That LED should not blink if the voltage remains on and steady. Were trying to find out if something is pulling that voltage down (or shorting it out...)
STEP #1 : Now...
) from the power supply- unplug all fans from the motherboard
- its the CPU
Turn on the power
