help decide between specs pls..urgent order
Weird case layout. "I find the lack of airflow disturbing".
I don't understand how they'd expect to get any air circulating around the components. No cable management? This looks like an outdated design :(
Depends if your case has an opening at the front to let the air through. I think the front door is vented, so you could theoretically remove the unused drive bays to let the air (and the dust) pass through. I supose for a temporary measure, it's worth a shot, and also seeing if it improves temps.
maybe something like this (Lian Li BZ-502A)
the front door is not vented so not sure how that would work unless I leave the front door open, but this would defeat a large part of the case's soundproofing...
I guess I can live with the temps, should be ok for casual gaming and vid editing; I am not into oc'ing much and will do it in limited stints i.e. while vid editing etc...
should tide me over for a few years :)
cheers
