Help :(! Disk read error??
:(! Any where I can go for help? Like any websites I should email or anything.
Got to Maxtors website, download the Test Utility (Seatools) and run it. It sounds like there is a problem with the disk itself, and at least the utility will confirm or deny that. Without knowing it's difficult to suggest the next move...
http://www.seagate.com/www/en-us/support/downloads/
How do I select repair? Do I have to boot from the disc? It wont let me do that as it says it cannot reconise a hard drive!
Can I do it from windows safe mode?
You need to enterthe BIOS and select your optic drive as the primary boot device. Failing that, pressing F8 during boot should give you a list of devices to boot from.
Make sure the XP install disk is inserted. The process will start copying files like a new install. When complete, select Install. After which it will detect an existing OS and will ask if you want a fresh install or repair. Select Repair.
