help fixing my partition please
22 Nov 2002
Liverpool
hi, i have recently resized my external drive with easeus partition manager software which was all ntfs i resized and tried to make a 25gb fat 32 partition which has gone wrong, i did have 1tb of data on this which i really dont want to loose :(
basicly it didnt go to plan i i cant access my drive now, each time i restart windows i get a prompt asking me to format the drive, i have gone in the recovery part of the easeus partition manager software i have been using and it searches and finds all the folders / files that were there, so they are there.
the only problem is i dont have a spare 1tb drive to save it all to, below is a screen shot of how it looks, im talking about the one thats highlighted:
http://img337.imageshack.us/img337/4705/newpicture2k.png
as you can see it says unformatted and that 1396gb has been used, so it seems to me the data is all still there, the drive just either doesnt have its mbr, which i tried to rebuild using the software but no good come of doing that, so im really not sure what to do next, it looks to me like it should be able to be saved as everything seems to be there apart from my pc not being able to read from it yet.
can anyone please advice what im to do next?
thanks
james
