- 9 Mar 2009
Built in firewall/anti-virus/spyware protection is hardly guff.
Works fine if you stay away from dodgy backalley sites I spose lawl, does the job.
Anyway, going off-topic..
Thanks greg for pointing that out, soon as you said virus ctrl alt delete and saw it right away. If you hadn't of said I wouldn't of suspected virus at all given it was a clean install.
Least its all ok, I am going to keep stressing the card and probably the whole system over night just be sure but thanks for the input people![]()
and glad I had read a thread or two with the same problem (just different GPU's).Works fine if you stay away from dodgy backalley sites I spose lawl, does the job.
Believe me you don't need to stay away from those if you use it.![]()
I had that virus with the same symptoms. I could not get rid of it it kept coming back even after I removed it blocked it etc. In the end I formatted and re-loaded and have not yet had anymore problems. Its a right pain in the butt.
od practice to reformat and reload your software regularly, this gets rid of all sorts of rubbish including viruses.
