HELP! Have a problem...
26 Feb 2007
Blackpool
Bsically my dad went to turn on his Sont Vaio PCG-9S2M today and everything was fine in DOS etc... until WinXP loaded and everything was so dark, with a bright light you coudl make the screen out in the background but its was so dark like the back light had gone.
I was just wondering, is it the graphics controller thats gone pap or the screen? or the backlight bulb?
Would be grateful for a quick response, thanks.
That implies software, not hardware.
Isn't there a button on Sony laptops that controls brightness? Also, some Sony app that runs in Windows, perhaps?
When i put in my Windows Disc the colour was all there :confused:
But when i load into XP the screen doesnt.
Even in safemode :confused:
And when the windows XP loading bar is there before it starts up it goes dark from there.
hmm, are you sure its actually not a duff install? you can put in an xp install disc and it runs fine?
maybe windows load up is really hung. choose safe mode command line with prompts and see how far it gets. (ie don't use the loading bar...)
