IDLE/LOAD - e6300/Stock (1.325v/1.275v) - ASUS P5B Deluxe - Thermalright Ultra 120 - Antec 120mm Case Fan - Fairly Quiet!
Wow at last I got it all sorted, as you can see the Ultra 120 is doing a splendid job of cooling the processor! Installation was easier than what I was led to believe, in the reviews they said it was a bit tough getting the screws in but it was quite easy, almost too easy and got me worried that I had done something wrong
I haven't got my Sharkoon 120mm fan yet so I clipped on an Antec 120mm case fan (stock exhaust fan from the P160, 4-pin molex) which much to my surprise is pretty quiet.
Still using my old batch of arctic silver 3, wanted to keep a level playing field as this is what I used on the Freezer 7 Pro (wondered if it had gone off and was mucking up the heat transfer).
Looks like the Arctic heatsink I had was faulty in some way? (I suspect its the fittings, they don't seem to apply much downward pressure?). The AC7Pro will have to go back to the store (gah RMA city this month I tell ya!) but I'm glad it was the heatsink rather than the CPU.
I noticed that TAT really does heat up the CPU a lot more than any other app/tool I've used before, I've done a bit of gaming and that doesn't come anywhere near the load temps that I get from TAT, more in line with the temps you would get from running dual-prime . . . speaking of which
Now I can get on with some overclocking . . . At last!
![Cool :cool: :cool:](/styles/default/xenforo/vbSmilies/Normal/cool.gif)
