- 15 Oct 2006
im scared to buy this now, i need reassurance!
Raikiri said:wonder what is actually wrong with the freezer, gonna try and find out or just bin it?
Van Diemen said:He wants his money back, I f-ing would
Its a shop so its going back (with a print-out from TAT), I coughed up £16 nuggets Because of all the hassle I have been through I will do my best to follow this up, I have liked Arctic cooling since I owned one of their GPU coolers (9800Pro one?) so clearly I am a bit suspect of them now. Obviously every manufacturer produces the odd 'dud' just a pain that I drew the short straw this time. The quality of manufacture on this Arctic HSF is pretty shoddy, but then again what can u expect for £16.00?Raikiri said:They are about £11 to buy, probably not worth the hassle/cost of posting it back tbh. And apparently AC's customer support isn't very good.
Nah in case but with side off (still faffing).monkeypants said:That's what it was like with my AF7, are you running outsde the case at the moment?
Dunno what to say really, there are so many people confirming decent results with their AC7-Pro's I can only conclude I got a minger.dirtyharry87 said:im scared to buy this now, i need reassurance!
well done mate ,good luck with OC ,i will get same parts next month !Now I can get on with some overclocking . . . At last!
hmm i wanted something better, and i never seen any good reviews about scythe infinity :/ , i will read some forums,besides it looks almost as AC7 and i realy need something more silent that AC7 ,and check what can i find out ,couse i realy was looking forward to Thermalright Ultra-120 :/scythe infinity
Hi vairo,vairo said:Hi Big.Wayne could u look at these pictures and tell me if Thermalright Ultra-120 Heatsink would fit in in my case or no ! And which 120 mm Fan would u recommend to me
as u can see in picture Thermalright 120mm would be great purchase for me , since i got quite good air flow in there with my 2x120mm Fans already ,case is TJ06 btw !
In this picture u can see why i am worryed ,there is no much space left :/ , anyways when i look at your pic ,i got a feeling that it shoould realy fit in ,but as i said ,i would like to be sure before i purchase one of these babys!
What are your recommendations,or ideas?
cheers vairo:
thanks mate , i dont have time today since i work quite a lot , but i will do it most likely tommorow and post the measures,please check this thread again some time this week, and you might be able to help me out ,i would realy appreciate it!What you will need to do is 'carefully' measure the distance from mobo to the side panel, when u know that then we can work out whats the best option for you.
I normally just use the Akasa fans, seem to do the job and they are pretty quiet actually, however I followed a tip and have tried some new fans from a company called 'Sharkoon', they have a product range called 'Silent Eagle', I've only used the 80mm versions so far but I'm impressed! (they come with sheathed cables and a nice bundle included rubber mounting grommets, bargain!)
well i measured it the distannce from mobo to side panel is 17-17.5cm , might fit in eaven 18cm ,but 17cm realy would be the max i would go for ! And if i am not wrong AC7 Pro highest point is about 13.5 or something! Distance from right side of my AC7 to the bottom of the case is 1.8cm (so i cant get very wide cooler aswell i guess ) i will takke more pics tonight or tommorow ,there might be one more probllem ,to consider!What you will need to do is 'carefully' measure the distance from mobo to the side panel, when u know that then we can work out whats the best option for you.
Hmmm will the Thermalright HR-01-775 fit in there?vairo said:Any ideas so far ?
