HELP! I need PC monitoring software!
4 Jan 2004
Greetings peeps.
Yesterday I discovered that one of the kids has got themselves onto websites like Bebo and others like it and has created profiles for herself (she's 11) using usernames that quite shocked me. Some of the things that have been said on her blogs etc are quite sexual but thankfully still in an innocent way. I told her that I've found things on her laptop and that I now have to do something to monitor her more closely. She's a bright kid but is easily influenced by others and I'm just getting concerned that she may just find herself in a spot of bother by simply not thinking straight.
I have spoke to her about the right and wrongs of the internet as best as I can but I can't expect her to take all of it in. I don't want to ban her from it either, just show her that it isn't as private as she thought it was and that because of that it can be a pretty scary place to be for a kid.
I need something that will monitor everything she does on her laptop. I've got a sneaky suspicion that she's been nipping downstairs and switching the modem on and running back upstairs to go on her laptop when we're asleep in bed.
The more functions that the software has then the better as I can show her that we can see everything she does. Hopefully she'll realise that we're not spying on her but just looking out for her own safety and that over a period of time I won't need to monitor her web access as that element of trust will come back.
So peeps, what's the best PC monitoring proggie that you can think of that would do the trick? If anyone's used any then I'd be grateful to find out what you all think of them.
Many thanks in advance
Al;)
If you don't trust her, then I would only allow her to use the computer while supervised. There are things like Netnanny which restricts access to certain sites, but this kind of thing would require some sort of key logging software. Best thing to do is password her pc and only unlock it when a responsible adult is about.
get a router with the ability to block certain mac addresses between certain times -ie, 10pm and 8am -if you're on cable, then the linksys wrt54GL is perfect for this (with Tomato firmware)
also, you could scare her by creating your own account, use some random picture and add her as a friend, then be all nice at first etc, and say "lets meet up" -her reaction will tell you whether or not you can trust her to use it.. :S
Thanks for the speedy reply folks.
She is running Vista on her laptop so I'll look into that suggestion in more detail.
I do trust her but like I've said she just seems to forget sometimes what the rules are and bends them without really knowing what kind of trouble she can get herself into. I know what I was like as a kid growing up so I want to try and find something that will do the work for me when I'm not around. She used to use the PC downstairs which was fine as it was in the dining room so it was easy to see what she was up to if I needed to, but now that her dad has bought her a lappy for xmas last year she uses that in her room now. I'm just trying this monitoring software approach as I think it will strike a nice balance between being too strict and not being strict enough. Just so that she knows that out of sight doesn't always have to mean out of mind if you know what I mean.
Who would've thought that being a new stepdad would be such hard work:eek::D
Al:)
Most home filters will allow you to log internet activity (some down to MSN chat logs etc) and also restrict access to certain sites at certain times etc.
It's a bit old but have a look here for popular filters: http://www.welfilterreview.com/
I suggest to try a trial if you can to make sure it does what you want :)
Burnsy
as i said above
router based filtering/blocking is a lot better than using software :)
which router do you have?
as i said above
Netgear RangeMAX WPN824 v2
Is this quite a technical process bledd because I don't trust myself to wire a plug:D Doesn't mean to say that if it's not that hard then I'll give it a go if the instructions are clear enough;)
Al
ask in the networking forum, i've never used any netgear stuff, i'd imagine it's possible though
you just need her mac address for her wireless card (can find this easily by doing 'ipconfig /all' in a cmd window from her machine)
it's a mixture of letters and characters, like this.. 0A-5E-9B-6A-00-AG, think of it as a phone number for her network card
you should be able to add a rule to the router that blocks access to 'mac address x' during xpm and xam etc..
here's a perfect example of it in Tomato firmware :)
http://www.polarcloud.com/v/screst.htm
what's her name?
i'll add her as a friend
Don't take offence but it wouldn't send out the right signals if I openly gave out to a complete stranger the name of an 11 year old girl as I'd be only contradicting what I'm actually trying to achieve in the first place:) Even though your intensions are good in your suggestion, it would only cover a small part of what monitoring software could do for me. Ta all the same though:cool:
Al
Had a look at the Vista controls and I'm maybe gonna see if there is software that will compliment what I've already got installed free of charge;)
Not to worry chief, I was in no way being serious.
Back on the topic, Vista controls are great. Add in rules (such as sites and access times) and it'll also log everything.
As long as you're the Administrator, and she's the user.
I'm gonna do a fresh install and set up parental controls on Vista tomorrow. Hopefully there'll be a nice wee free program that I can use to compliment what I've already got. TBH I can't be bothered with all this messing around ... bloomin kids:mad:;)
Al
as i said above
I disagree for several reasons:
Firstly, software has regular updates for banned inappropriate material
Secondly, it can have much better reporting of logged activity
Thirdly, You can have much better flexibility for when to ban sites, like you could only allow bebo access for a max of 1 hour each day
Forthly, it'll work whereever she has her laptop be it at home or over a friends.
Fifth, it's generally easier to set up and maintain
So like I said, have a look at the range of software based solutions ;)
Burnsy
