- 20 Oct 2009
- Deepest, darkest Essex
In a bit closer...I'm rubbish with a cam but you can see the same result as you have now
I do have one of those, there's 3 connection points on the 1 cable, does it matter which one I use?
Are these pics helping?![]()
A tonne. Got the power into the HDD, and the other blue cable to the motherboard. But there's still one tiny slot. 4 tiny pins wide.
Essexraptor - could you link me to the extension cable you have for your 8pin to mobo cable(top left next to CPU) - I need one badly and not sure what to buy - this is what ive found
6pin to 8pin
http://www.overclockers.co.uk/showproduct.php?prodid=CB-033-AK&groupid=701&catid=48&subcat=153
8pin to 2x 4pin
http://www.overclockers.co.uk/showproduct.php?prodid=CB-022-AK&groupid=701&catid=48&subcat=153
or (which I think is what you have)
http://www.overclockers.co.uk/showproduct.php?prodid=CM-001-NX&tool=3
Maacck - builds looking good, that antec 1200 would appear to have a whole world of room compared to my 902.
Also EssexRaptor, did your case come with a PWR LED cable, the tiny tiny one. Cause mine didnt.
dunno if anyones mentioned this yet, but image 3 is wrong. The cable plugged into your PSU does not go there (the one with a 6pin connector one end and two flat 4 pins on the other). They are used as converter cables for graphics cards. TBH with that power supply you shouldnt be using that cable at all. The only cables that plug into the power supply box are the ones that came supplied with the power supply itself.
I think he has ripped it all out and started from scratch to be honest![]()
