its looks a bit messy. dunno how u guys keep everything so neat.
anyway when I turn it on it beeps twice continuously with 1 second pauses...like beep beep.......beep beep.... etc etc whats that about?!? Its not the bios beeps, it gets past that and I can get into windows if I wanted to (if I had it installed). I also checked in bios to see if I needed to disable the fan warnings, but they are all disabled anyway.
I dont have any of the fans (inc the Tuniq tower fan) connected to the motherboard, they are all connected to the Zalman fan controller (which is connected to the psu). All the fans are working though, although I did change one down to 60rpm on the controller and it made no difference to its spinning..
Any ideas what this beeping is about?
