Help!!!! Major computer problem
8 Jul 2014
Hi I built a computer a while ago and it works fine until I play games for a while then I get a complete computer crash and it's really starting to worry me it runs fine when I leave it but as I said gaming can crash it I also sometimes doesn't when I say crash what happens is the image stays on the screen and everything freezes any help would be great thanks
BM
Sounds like somethings overheating or clocked too high.
Have you clocked the system? CPU? RAM? Graphics Card?
If so, go into the BIOS and reset it back to default settings, then test again.
If not, get yourself a temperature monitoring program, some may have come with your motherboard and graphics card software, and monitor the temps when your playing your games. Figure out whats getting hot.
You could also check Windows logs to see if its reporting anything useful.
Ok well I have a few event ID problems here are the numbers critical:41
Error:3,10,137,257,512,6008,7000,7009,7011,7024,10010
Warning: 4,27,123,219,1014,10010
Thanks BW
All parts for my PC
Case:NZXT Phantom 820 (Black)
CPU:AMD FX9590 Black edition
Motherboard:Asus Crosshair V Formula-Z
GPU:Asus 780ti in SLI with another Asus 780ti
RAM:Avexir Core 16GB
PSU:Cooler Master V1000
CPU Fan:Corsair H100I
Extra Fans:Noctua 140mm for now
SSD:Crucial 240GB
HDD:2TB WD Drive
Drive Bay 1:LG Reader/Writer
Drive Bay 2:NZXT Sentry 3
And all drivers are up to date to my knowledge but ill have to check soon many thanks BW
you enabled xmp profile for your memory in the bios? might need bit more cpu northbridge voltage with 16gb not sure what its labelled as on amd systems
would 1000w PSU be ok for that system?
i know that sounds silly, but a normally system would be ok however you have
200W+ CPU
2 x 250W+ GFX cards
under load your at around 650w to 750w without all the other items, and RAM, Mobo, fans, water pump, HDD's, LED's? that all add up to over 250w easy, the high clock AMD chips are also well known for killing motherboards
