My heads clear now.
Shocky if you change your bios to 1004 it will give you v.core options up to 1.65v.
Ill see if I can find the thread on EOC and give you a link.
My X2 3800 was stuck at about 2.76 till I removed the IHS.
Removing the IHS will almost deffinately get you to 2.8 but you would loose value on the chip if you decided to sell.
EDIT/ I found the thread on EOC, link below
http://forums.extremeoverclocking.com/showthread.php?t=202887
Its the last post.
Its the last post.
