I was hoping top upgrade to ultra wide 1440p with freesync, but it seems silly to play the IPS monitor lottery when spending well over £400.
I settled on a BenQ 2730Z, get to unpack it after a coffee, shortly.
My first ever non-Iiyama PC monitor!![]()
just buy a 32" samsung or sony tv.
get their most expensive 2015 model.
I was going to upgrade my 10 year old 24" dell 2405fpw but iam not sure now. Was looking at the 27" dell 2715 or the 34" dell superwide.
  Mine finally got a stuck pixel last week, after about 8 years of daily use.Let me know what you think.![]()
 but a TN panel? - I tried with an iiyama 28" 4k but it had go back as  I could not get used to the colour fade; then again the gsync may make it acceptable - would appreciate your thoughts once it is up and running.
 (I did change recently and went , in the end, to the Dell 34"
 I thought it would be draw dropping...I can't really tell much over the Dell U3415W TBH...and that was a 60hz panel... The colours are not a patch on the U34 period...
Of course they aren't... one's a IPS panel and the others TN.
TN panels are fast and IPS have good colour reproduction. Not sure what else you were expecting? Gsync stops tearing nothing to do with grainyness or anything else image quality related for that matter. As for not buying Acer at any price, thats idiotic.
Would agree that at this price (Dell or this one) it should not be a panel lottery
Overall I believe that you have a few options:-
1. Have another try with the Dell (but back to luck of the draw.)
2. Try one of the va panels e.g 40" Phillips or AOC /Ben Q 32".
3. I was very tempted to get the 4k Benq 32" - only prob is that it is out of stock at the moment.
4. If you can cope with it go for the Hanspree 27" IPS and hold the 'big' purchase until the next gen of monitors are out.
Good luck![]()
