Help me with my bike rattle cycling brothers - please
Man of Honour
29 Mar 2003
Stoke on Trent
This is doing my head in.
My bike has developed a rattle/noise and I can't find it. If I turn the bike upside down I get no noise at all when spinning the wheels. The noise gets louder when I'm freewheeling! I can also feel the clicking through my feet and obviously if I put my hand on the frame.
Help me oh wise ones.
Have you had the wheel out of the dropouts recently? It might be skipping if it's not seated properly.
The fact that it's worse when freewheeling definitely points to something at the back wheel rather than at the pedals, and that it happens at all when freewheeling suggests it's not to do with the chain eg bad routing through the derailleur jockey wheels.
Something around the freehub does seem most likely. It's odd that it doesn't happen when pedalling with the bike upside down, but that could be to do with having weight on the wheel.
This morning it was still making the noise and after saying good morning to Mark Hughes on the Britannia Stadium car park (serious) I realised I had to stand up, it still made the noise.
Now I can't remember if it made the noise all the way to work but when I came out and rode home it was silent :confused:
5 out of 6 commutes have been noisy except the last one, it doesn't make sense.
Free hub on the rear, I'd say that you have lost/mangled one or two bearings. You won't get the noise upside down as their isn't enough weight on the wheel. Also check your wheel is true after you get it sorted, I'd a similar problen and the rim had to be replaced as I didn't notice in time.
