Help! My first build
Did it.
When I turn it on it comes up with
"All settings were restored to default values"
"Detected ATA devices: SATA port 2: CDDVDW"
nothing about the hard drive in port 1
I don't think so, I have tried the hard drive in every single port and the problem has persisted. I have also tried the CD drive in every port and it has been fine.
Unfortunately all my friends have macbooks :/
I'll send it back. If they find no fault then OC can help me fix my problem and I know it's not the hard drive that's at fault; if they do find an issue then I get a shiny new hard drive.
Seems the best way.
Thanks for all the help everyone
Update!
I deconstructed my now broken laptop and used the 160GB Hard drive from that, and it was detected by the BIOS fine. Definitely seems to have been a hard drive issue, which was received today by OCUK to test.
Exploratory question - If I were to load windows onto my hard drive using its code, how would I then delete it from the 160GB and load it onto my new hard drive when it gets back to me?
I have no idea how long RMA takes so I am trying to find a workaround :)
