Hello, thanks for your time for looking at my post.
I have around £800 budget to make a new gaming pc.
I have an old skylake pc which I can salvage an old Corsair 850M psu, Gtx 1080, 2x 250gb ssd and a gaming monitor and would like to reuse these.
Other than that, I don't have a preference for amd vs intel.
I would prefer a m.2 as my main hdd, prefer a White case with some aesthetics like a glass panel and some rgb and noise issue is not problem. And probably at least 16gb but prefer 32gb memory.
Quick edit: I also need wifi and happy with onboard sound.
I would like the focus to be on upgradability on the mobo as I will likely replace the cpu and gpu in the future, though overclocking isn't a must.
I will be gaming on this machine on a Samsung G9.. but let's not focus on my gpu problems at the moment as I'm happy to play on lower settings for now.
