help on new build
Havent had time yet to rebuild the pc hoping to find some time this week ..
just thinking as ive never used AIO cooling. the fact it worked and the fans run makes me think its ok
but could it be giving erroneous readings and lighting the cpu failure light, is this a possibility or am im clutching at straws.
The cooler running just shows theres power there, overtight cooler usually gives CPU or dram error
Just remember to build outside the case with CPU, motherboard one stick of memory , if you attach the cooler just Finger tight. All you want at that point is to boot up into the bios.
will i need to attach the gpu as well as no onboard graphics i think
