help on overclocking
10 Jun 2007
hi everyone i just bought this system 20days ago and finally after all the hassles i hav got it set up and ready for overclocking..
the system is
crd 1.80ghz ( stock cooling )
2gb gskill 800mhz
asus p5k motherboard
nvidia geforce 8800 gts 320mb
550w ocuk huntkey power supply
nzxt apollo gaming case
i am new to this overclocking and hence need a lot of advice i have a stock cooler on the cpu and 3 fans in my case two for intaking air and one to take out the air. if anyone has a asus p5k board then plz help me out with overclocking and also the right optimisom i need.
thanks in advance
I can walk you through how to begin with a P5K Deluxe board, if you like; it shouldn't be too different from yours. Here we go:
In the BIOS, navigate to the "Advanced" menu and enter the "JumperFree Configuration" sub-menu. Here you need to set "Ai Overclocking", "CPU Ratio Control", "DRAM Frequency" and "DRAM Timing Control" to "Manual".
Navigate to "Ratio CMOS Setting" under "CPU Ratio Control" and press "+" or "-" on you keyboard until it's at its maximum (sorry, i don't know what it is for your chip). Then, increase the "FSB Frequency" by 30Mhz, set the "PCIE Frequency" to "101Mhz" and "DRAM Frequency" so it matches the "FSB Frequency". Now set the "DRAM Timing Control" as follows:
CAS# Latency - 5
RAS# to CAS# Delay - 5
RAS# Precharge - 5
RAS# Activate to Precharge - 18
(Can someone else confirm the above latencies are appropriate)
Now, Disable "CPU Spread Spectrum" and "PCIE Spread Spectrum" and set the "CPU Voltage" to 1.4v and "DRAM Voltage" to whatever is the recommended setting for your particular memory. Everything else in this sub-menu can be left on "Auto".
Exit "JumperFree Configuration" and, still in the "Advanced" menu, enter the "CPU Configuration" sub-menu. You should see that the "Ratio CMOS Setting" here is the same as what you set it to in the previous sub-menu; that's fine. Disable "C1E Support", "Max CPUID Value Limit" and "Vanderpool Technology".
OK, you should be just about done. Bear in mind that your BIOS settings may differ slightly from what i've written here but, hopefully, the basics should be very similar. Oh, and, before you start changing your BIOS settings to what you see here, i'd wait until you have more input since i may've made some mistakes.
ashmanuk67 said:
Is this the same for pc8500@1066 rated memory.
Well, in order to get the most out of PC2-8500 memory, you'll need to increase the "DRAM Frequency" to as close to 1066Mhz as possible. If the nearest option happens to be greater than 1066Mhz, some of the timings may have to increased, as well as the "DRAM Voltage". Apart from that, it's all the same.
parmz_11 said:
how can i overclock my geforce 8800 gts, i was looking at these software
rivatuner and ati tray tool but i dont no how to use it.
They are both pretty easy to use. Although, i can't get the overclock on either of them to "stick" on my 8800GTX. Anyway, with Rivatuner, click on "Customize" under the "Driver settings" section on the "Main" tab and select "System settings". Then all you have to do is move the "Core clock" and "Memory clock" sliders over to the right, hit apply. If you want to, after you've hit apply, click on the save button in the "Overclocking profile settings" and name your new overclock so you can quickly select it at any time in the future. You can also tick the "Apply overclocking at Windows startup" box and then hit the save button to the right of it. This should make your overclock "stick" when windows loads (bear in mind that you have to make Rivatuner startup during bootup), however it never works on my system. I think it's because, what ever i do, Vista blocks Rivatuner from automatically starting up properly when Windows boots.
With ATI tool, click on the "Settings" button, and then tick the "Apply clock immediately after moving slider" box. Well, actually, it's up to you but i find it easy this way. Then, in the main window, just increase the "Core" and "Memory" sliders in the "3D perf." section on the right. and you're done! However, with ATI tool, i don't think it's possible to make the overclock "stick", so it has to be applied manually or with use of a profile once you're in Windows.
Whichever utility you use, make sure you run the "Scan for Artifacts" feature in ATI tool to ensure your card is stable at the overclocked settings. I also advise you to increase your fan speed in Rivatuner because, otherwise, you'll probably find your card getting pretty hot. I usually have mine around 70-80%.
If you'd like, you can click on "Find Max Core" and "Find Max Mem" in ATI tool to find your card's optimum settings for you. However, i've found that it increases the clocks too far and, everytime i use it, it either bluescreens or reboots because the clocks are too high. May i suggest, if you do go this route, set an appropriate "clock safety range" in the "Settings" window because ATI tool might just keep increasing the clocks and damage your card; that is, if it doesn't reboot itself before hand.
I hope this had been of some help. Good luck!
hi i tried this rivatuner and did what you said. but when i say enable drive level overclocking it tells me to reboot detect or cancel
when i detect it says itscore clock 770mhz and memory clock 1160mhz
it wont let me go more than that.
hi mansize tissue i did what you told me and seems to be working my max multiplier is 9 and my systems is seeming fine.
details now
core speed 2070,8mhz
bus speed 230mhz
rated fsb 920mhz
voltage 1.272v ( i set it at 1.3 instead of 1.4 )
memory
frequwncy is 286mhz ( b4 when i used this *** thing it was 368 )
fss;dram 4:5
cas latency 5
ras to cas 5
ras precharge 5
cycle time 18
can i do any better than this.
hi just posted 2270mhz
bus speed 246mhz
rated fsb 980mhz
voltage 1.304v
my temps according to the bios says
46 degrees b4 it was 34 degrees
what is the max temperature i can run a cpu
Probably about 70c but I would try to keep below 65c. You should download a windows based temperature monitor program such as speedfan, I use everest ultimate edition to monitor mine and do stabilty tests.
It's important that you find out what your CPU core temperature is under load. Get SpeedFan, that way to can check your motherboard temperature, too. Also, get Orthos and start using it to stress your CPU. Really, you want to be able to run it for at least 8-hours without it stopping or rebooting your computer. Whilst running it, check what your core temperatures are and system (motherboard) temperature is on SpeedFan and report back.
