Help out an old timer...!
OK, so I just checked out the watercooler as suggested by Bacon? and realised that the fan is situated remotely. Nice. I thought it was just the block, silly me....
Some further suggestions would be great though.
Thanks again.
Apologies, my reply may have sounded like I completely disregarded your suggestion. That wasn't my intention.
I guess the reason why I haven't considered mATX is because nobody has recommended one. More reviews to search for :)
Thanks
Thanks
No apology necessary.
Most people associate mITX with HTPC, so don`t check that the Case will also take an mATX mobo. As long as the mobo you chose meets your needs, then size is irrelevant. ;)
I was swaying towards the Gigabyte ITX, I'll look at some reviews and shootouts today if I get the opportunity!
Thanks. Are there alternatives to the antennas? Or perhaps in internal PCI card that would give me wireless functionality?
All the wireless cards have antennas.
http://www.overclockers.co.uk/productlist.php?groupid=46&catid=1597&subid=1622
You could use a USB adapter.
http://www.overclockers.co.uk/productlist.php?groupid=46&catid=1600&subid=2033
Are you really going to see the antennas, they will be situated at the rear after all.
Seems a bit pointless buying a wifi board, then installing another adapter.
I was looking for something similar to this. Thanks for the link. I guess once I factored in the price of two of those and then postage, I may as well stump up the cash for a P8Z77.
I'm really tempted by it now.... :confused:
Decisions, decisions, not easy. But the Asus would make more sense in your case, although a bit more expensive, it would be less hassle, as in finding suitable antennas.
I'd agree.
Quick question if I may. Regarding the graphics card, is it necessary to go for one of the all-singing, all-dancing models or is that only really necessary for certain games? I really like the pricetag of the Giagabyte 7870 Windforce 3x card but couldn't justify spending any more if I'm honest. What sort of difference are we talking about if spending £100 more? Bearing in mind I'm not a huge gamer, it's just Skyrim I'd like to play with all it has to offer. Other games like Crysis, COD, Dishonoured I can really live without.
