Help overclocking E6600
4 Sep 2005
Lowestoft
Hey guys i over clocked before on my P5NE-SLI but it went fault so i had to buy a new board asap. I got a Asus P5P41C. Can anyone help or direct me to a thread about overclocking this board or a bios similar as its no where near the same options my last board had and id really like to get it to 3.0-3.2mhz as i know my gfx card atm is not performing how it use to.
Thanks
Overclocking the processor won't impact your GFX card's performance. You can overclock the card separately using Riva Tuner.
What do you mean by the GFX card not performing like it used to?
I've been running my E6600 as 3GHz for the last 3 years without any issues. I basically followed the advice here:
http://vip.asus.com/forum/view.aspx...P&id=20071005044049234&page=1&SLanguage=en-us
I can't find a similar thread with the BIOS screens for the P5P41C and the Asus forum has very little content for this board. Are they anything like the P5B Deluxe in the link above?
In order to run a stable overclock with the E6600 I've found that the processor doesn't need a lot of Core volts, in fact it's stable with below the default voltage for running at stock. I have it set to 1.2875 at the moment in BIOS, which equates to 1.24 in CPU-Z. As you probably know, the lower the voltage the better as voltage equates to heat and too much heat will damage the processor.
My advice would be to do things in this order:
Ensure that you have a recent BIOS installed (don't update within Windows).
Download and install the latest versions of CPU-Z, Orthos and Coretemp
Check your temperatures are OK running at stock (CPU should idle below 50 degrees). If temps are high it may be down to dust in the case.
Increase the FSB slowly and check stability each time by ensuring you can boot and then run Orthos blend test. When you have the desired overclock, reduce Core voltage to minimum required to be stable (no errors in Orthos for 12 hour run).
You can also check stability of RAM by running MEMTEST (runs from CD on boot).
You may need to lower the DRAM frequency as it steps up with the FSB on the P5B Deluxe, not sure if that is the same with your MB.
Do you have the stock cooler?
Lawrence
Hi m8 thanks for reply, My cpu is currently @ 2.4 "stock speeds"
My rig is running a ultra 120 with 2 120mm fans so is defo up for the job for overclocking and the idle is around 25 - 28oc
This motherboards bios seems like its a stripped down version "running latest bios" Its nothing like my old one was. All i can find is CPU Frequency and Dram frequency
Ill take a look @ my bios with the provided link u gave me and see what i can do :)
Thanks
Even with a limited set of options it looks like you can make the necessary changes.
You should be able to get to 3.2 without too much difficulty. Make sure you monitor temps though.
