can someone help me with a good solution, i have my pc and projector screen on the same wall and i want to run my projector onto the screen from the opposite wall or ceiling, it'd be easier to put the projector on a floating shelf or maybe some furniture (id have to move my bed but thats cool) just want a neat solution so i dont see many (or any) wires, and keep the distance down so i dont have a massive hdmi run for quality reasons
any floating shelfs or units or any bits of furniture or mounts you can recommend
i have a wall light that i want to take off under the shelf, could that be replaced by a 3pin plug?
