Help Please - Intel Haswell Build
19 Aug 2013
Hello there peoples,
I'm planning on building a Intel Haswell PC by the end of the year for use with gaming and rendering.
I have a budget of around £3000-£4000 but it can be stretched if need be.
I put together this list of parts:
Case
Corsair 650D ATX Mid Tower Case
CPU
Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler
Corsair H110 94.0 CFM Liquid CPU Cooler
Motherboard
Asus SABERTOOTH Z87 ATX LGA1150
Memory
2x Corsair Dominator Platinum 16GB (2 x 8GB) DDR3-1866
Storage
2x Samsung 840 EVO 500GB 2.5" Solid State Disk
1x Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive
Video Card
Asus GeForce GTX Titan 6GB
Optical Drive
LG BH16NS40 Blu-Ray/DVD/CD Writer
Power Supply
Corsair AX760i 760W
Monitors
2x BenQ XL2420T 120Hz 24.0" Monitor
Keyboard
Razer Blackwidow Ultimate 2013 Wired Gaming Keyboard
Mouse
Razer Taipan Expert RZ01-00780100-R3U1 Wired Laser Mouse
However, my friend suggested a few modifications; which are something along the lines of:
MSI Z87-G45 Gaming Series Intel Z87 - http://www.overclockers.co.uk/showproduct.php?prodid=MB-235-MS&groupid=701&catid=5&subcat=2574
Seasonic 860w '80 Plus Platinum' Modular Power Supply - http://www.overclockers.co.uk/showproduct.php?prodid=CA-015-SS&groupid=701&catid=123&subcat=2383
2x Patriot Venom Red 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz - http://www.overclockers.co.uk/showproduct.php?prodid=MY-090-PA&groupid=701&catid=8&subcat=1387
2x Asus GeForce GTX 670 - http://www.overclockers.co.uk/showproduct.php?prodid=GX-290-AS&groupid=701&catid=1914&subcat=2294
1x Samsung 500GB SSD 840 Basic - (MZ-7TD500BW) - http://www.overclockers.co.uk/showproduct.php?prodid=HD-163-SA&groupid=701&catid=2104&subcat=2394
2x Seagate Barracuda 3TB 7200RPM - http://www.overclockers.co.uk/showproduct.php?prodid=HD-256-SE&groupid=701&catid=14&subcat=1955
2x BenQ GW2760HM 27" Widescreen LED Monitor - http://www.overclockers.co.uk/showproduct.php?prodid=MO-083-BQ&groupid=17&catid=1120
Logitech G500S Mouse
any Ducky Brown Switch Mechanical keyboard
Can you guys help me figure out the best parts to use in my build? :)
Your help, to put together a great build, would be greatly appreciated ^_^
Yum...
YOUR BASKET
2 x Asus GeForce GTX 780 Direct CU II OC 3072MB GDDR5 PCI-Express Graphics Card £569.99 (£949.98)
1 x Acer HN274Hbmiiid 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision Glasses £299.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £193.99
1 x Corsair AX860i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020037-UK) £179.99
1 x Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £179.99
1 x Microsoft Windows 8 Pro 64-Bit DVD - OEM (FQC-05955) £114.95
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £99.95
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9) £89.99
1 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9R) £89.99
1 x Corsair Carbide 300R Mid Tower Windowed Case - Black £69.95
1 x Corsair Vengeance K65 Compact Mechanical Gaming Keyboard (CH-9000040-UK) £69.95
1 x Corsair Generation 2 Sleeved Cable Kit (AXi / AX / HX / TXM) - Red £64.99
1 x Corsair Vengeance M65 Laser Gaming Mouse - Black (CH-9000022-EU) £54.95
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £41.99
2 x Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan £15.98 (£31.96)
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
Total : £3,045.64 (includes shipping : £27.55).
And then stick it all under a custom water loop at a later date. Plexi blocks, red coolant, very nice.:D
Couple of things Tom, why not go for a bit more of a nicer case, and perhaps go for a air cooler, and why Red switches? :p
Case is personal preference really. I picked a high quality mid range case. Could stick it in something nicer I suppose. :p That's not to say that the 650D isn't nice. And reds are good for gaming. :)
I would do this:
YOUR BASKET
1 x Sapphire HD 7990 6144MB GDDR5 PCI-Express Graphics Card £799.99
2 x BenQ XL2420T rev2.0 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red /w Flicker FREE Technology £319.99 (£639.98)
1 x Samsung 500GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE500BW) £289.99
1 x Silverstone Strider Gold Evolution 1000w '80 Plus Gold' Modular Power Supply (ST1000-G) £179.99
1 x Gigabyte Z87X-UD3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £158.99
1 x Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) HDD £128.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £111.98
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x Gigabyte Osmium Mechanical Gaming Keyboard - Red Switch £103.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV38G240C0K) £73.99
1 x Patriot Venom Red 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV38G240C0KRD) £73.99
1 x LiteOn IHES112-115 Internal 12x SATA Blu-ray Bulk Combo - Black £61.99
1 x Gigabyte Krypton Dual Chassis Gaming Mouse - Black/Blue £54.98
1 x BitFenix Alchemy Premium Modding LED Strip - Connect Red 60cm £25.99
1 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £25.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
3 x Aerocool Shark Devil Red Edition LED Fan - 140mm £7.99 (£23.97)
1 x BitFenix Alchemy Molex to 4 x SATA power extension - Red £6.98
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
2 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved red/black £5.99 (£11.98)
3 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£17.97)
1 x BitFenix Alchemy Internal USB Extension 30cm - sleeved red/black £4.98
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
Total : £3,229.24 (includes shipping : £27.55).
Yum...
YOUR BASKET
:D
£3000 build and the best you can do is a 300R. :( :D
It should be a 650D ;)
I cant read.
But anyway, replaced it.
YOUR BASKET
Total : £3,087.67 (includes shipping : £27.55).
I cant read.
YOUR BASKET
thays kinda like a Ethermaster special :D
If you really did want to go mad :D
YOUR BASKET
2 x MSI HD 7990 6144MB GDDR5 PCI-Express Graphics Card with FREE GAMES £499.99 (£999.98)
3 x BenQ XL2411T 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £249.95 (£749.85)
1 x Antec High Current Pro 1000W '80 Plus Platinum' Modular Power Supply £214.99
1 x Creative Sound Blaster ZxR PCI-Express High Performance Sound Card - Retail (70SB151000001) £199.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £155.99
1 x Corsair Vengeance K95 Mechanical Gaming Keyboard - Red Switch (CH-9000020-UK) £129.95
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £94.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x Corsair Vengeance M95 Performance MMO/RTS Laser Gaming Mouse - Gun Metal Black £69.95
2 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99 (£51.98)
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack £13.99
4 x BitFenix Alchemy 8pin PCI-E extension 45cm - Red £6.98 (£27.92)
1 x BitFenix Molex to 4x SATA Adapter 20 cm - sleeved black/red/black £5.99
1 x OcUK Professional 2.5" to 3.5" SSD Adaptor Plate - Black £5.99
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£11.98)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Red £4.99 (£9.98)
3 x BitFenix Alchemy 2pin I/O extension 30cm - Red £3.95 (£11.85)
Total : £3,809.10 (includes shipping : £38.25).
