Help Please - Intel Haswell Build
YOUR BASKET
2 x KFA2 GeForce GTX 770 LTD OC 2048MB GDDR5 PCI-Express Graphics Card **WHITE EDITION** with FREE GPU Keyring £369.95 (£739.90)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
3 x BenQ XL2411T 24" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £249.95 (£749.85)
2 x Corsair Dominator PLATINUM 16GB (4x4GB) DDR3 PC3-15000C9 1866MHz Dual/Quad Channel Kit with DHX Pro Connector (CMD16GX3M4A1866C9) £199.99 (£399.98)
1 x Seasonic 860w '80 Plus Platinum' Modular Power Supply £179.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £155.99
1 x Asus Xonar Essence ST Sound Card £134.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x BitFenix Shinobi XL Full Tower Gaming Windowed Case - White £129.95
1 x Corsair Vengeance K95 Mechanical Gaming Keyboard - Red Switch (CH-9000020-UK) £129.95
1 x Microsoft Windows 8 Pro 64-Bit DVD - OEM (FQC-05955) £114.95
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x Edifier R1600T Studio Plus 2.0 Monitors £77.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x Corsair Vengeance M95 Performance MMO/RTS Laser Gaming Mouse - Gun Metal Black £69.95
1 x BitFenix Alchemy Cable Bundle - White £28.45
5 x Noiseblocker NB-eLoop Fan B12-4 - 120mm £13.99 (£69.95)
1 x NZXT CB-LED20-BU 24x Blue LED Sleeve - 2m £13.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - White £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - White £6.49
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - White £5.99 (£11.98)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - White £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - White £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - White £3.95 (£15.80)
Total : £3,690.86 (includes shipping : £43.60).
Can make it more blue if you want :D but the white will set it off I think with the blue lighting.
YOUR BASKET
Just been looking through. The motherboard says that 1866MHz memory is only supported with OC. Will it still work or is this just me being too cautious?
P.s. I'm not a huge fan of the white unfortunately >.<
4k and no custom watercooling included?!!
OP didn't say he was open to the idea/experienced with watercooling/confident enough to risk spilling fluid over £4000 of components, so we assumed best not. :p
If you want to put us right on that OP we will gladly spec you something a bit more special. :D (but inevitibly less powerful :()
You're right. I don't really want to risk it with watercooling :) I wouldn't really know what I'm doing with it.
Its fine, the RAM has an XMP profile, so just load that in BIOS and the Mhz+timings etc are all taken care off for you.
