Need the ambient temps as well tbh so to see what the delta is. It's been damn hot this last week.
Been at the bottom may be restricting some air flow due to space from bottom of case to table/desk top
Are the fans pulling the air or pushing ? Looks like pushing from the pick. Try the other way, I know its putting heat into your case. Try it to see if pulling air from outside helps
so ambient temps around 26 idle temp 31 tonight i hit 64c under load the radiator was roasting and heating bottom of case. Ill flip the fans around and add 2 120s i have spare under radiator as well to push. Ill report back in a few hours once done and tested ....
