Help please
29 Nov 2006
Ive never used a SSD before i dont quite understand them yet. im buiding a new computer after 2 years of not using a pc (gamer) and as i was picking my components i noticed SSD's and came straight back to OCuk to find out what the hype was about and found everyone using them.
first id like to know
how do u install Win7 OS on a SSD?
(is it just the usual plug it all in, insert OS disk and away you go with the install)
can i use a SSD for my OS and also install my games on it and run them?
or do i need 2
whats size SSD is best to use?
i was thinking a 60-90gb
thanks all :D
Install is exactly the same as a old HD
Yes you can install your games on another drive (you might want to put your most played game on the SSD though)
would get 120GB + make sure its a newer one as they are faster.
