Hey guys,
Im in the middle of installing my new system and im really finding it difficult
Im trying to install my maximus hero xi into my phanatek evolv x case. First problem ive got is the front fan hub, the lead needs to be put into the EXT Fan connector correct? If this is correct then my lead from the hub isn't long enough to reach n not only that its only 4 pin while the header is 5 pin, would this matter? do I need a extension cable? Other stuff I could really need help with is the RGB, never installed this before and unsure which port to put it. I think its the addressable port but ill go more into that if anyone is able to firstly help and advise me what to do with the fan hub. Another thing ive installed a AIO for the first time, ive put the fan pump lead from this into the aio fan header at the top of the board, ive connected the two fans on the radiator to the leads coming from the unit itself and im left with a sata connector which I believe i connect to the psu. Does this sound right
plz help, Im stuck
Thanks
Im trying to install my maximus hero xi into my phanatek evolv x case. First problem ive got is the front fan hub, the lead needs to be put into the EXT Fan connector correct? If this is correct then my lead from the hub isn't long enough to reach n not only that its only 4 pin while the header is 5 pin, would this matter? do I need a extension cable? Other stuff I could really need help with is the RGB, never installed this before and unsure which port to put it. I think its the addressable port but ill go more into that if anyone is able to firstly help and advise me what to do with the fan hub. Another thing ive installed a AIO for the first time, ive put the fan pump lead from this into the aio fan header at the top of the board, ive connected the two fans on the radiator to the leads coming from the unit itself and im left with a sata connector which I believe i connect to the psu. Does this sound rightplz help, Im stuck
Thanks
