I will let you on a little secret.......
when you make them it doesn't really matter what colours you use as long as each pin out is the same colour at each end to make a straight through cable.
But then what would happen when I plugged premade cat5e cables to connect my devices into the rj45 sockets on the walls?
Would the wrong order of cables not mess things up?
Ahh i've got you,
I will keep them the way you posted though as thats the standard configuration right?
standard colours yes.
