Help quick
25 Oct 2006
I have just put together this build:
P5B-E
E6300
Corsair XMS2
Upon first boot i cant get into bios setup by pressing del key then it goes on to a screen that says
NO IDE MASTER HDD detected
cmos settings wrong
overclocking failed
Go into SETUP.
and a whole load of other stuff detected ram and sata hdd etc and then it shuts down in 15 seconds.
But i cant get into setup as it doesnt work.
SATA HDD
IDE DVD-DLR/W
I have tried resetting cmos via manual instructions but was no different. I can get into bios ez flash utility by press alt+F2 though. anyone got any suggestions?
i have just updated bios aswell and it still doesnt work. before it goes to the above stuff it shows 0DD): NEC Dvd - (serial number)
press any key to continue and then it goes to stuff above.
Please help soon, i need this pc up and running soon.
noticed there was different color sata ports on that board i think 4 red and 2 black, wonder if it makes a difernece wich color it in when you first install.
i take it its a neww hdd can you hear it spin up when you power on ?
i had this problem when setting mine up i found out it was the sata hard drive in the wrong slot on the mobo i thought it would go in the number 1 connection wich is red but then found out it was the first of the balck ones i dont know why or how this solved the probelm it just did lol.
Hope i help in a little way.
Steve
