- 1 Mar 2019
Do you mean you updated your drivers before it started to happen, or after?
Is the PC on in that time? Like does it go to sleep, or is it doing something?
So how do you know that discord is working?
I'm just trying to understand whether you're certain that it's a graphics output issue or it's something more fundamental.
Its a reference 2080ti with waterblock, bought from OCUK about 1.5 years ago
average temps are about 45 degrees, normally maxes out around 60-70 under load as ive got the whole thing on a liquid loop.
