Try to run Unigine Valley or Heaven for 30 mins in a window checking your CPU/GPU temps and clocks. Make sure nothing is jumping around clocks wise.
did you do this? does sound like its hapening only when the gpu is in proper use. the benchmarks you are using are not gpu benchmarks they are cpu ones.
