Decided to upgrade my XP2600 with a new XP3200 CPU and its causing a few problems. The mb is a DFI Infinity NF2 Ultra (rev.A) and mem is 1GB PC3200 DDR.
Took all the normal precautions and replaced the CPU, powered up and nothing, not even a green monitor led, the only activity is from the HD's spinning up! Checked all cards and leads and the PSU's o/p's and all ok. So replaced the old XP2600 CPU and the same nothing.. I dont know the bios rev as I cant power it up, sos cant contact DFI either! From waht I understood the mb should auto detect the new CPU and there were no jumpers to change. Do I need to change anything in the bios for the new CPU? Strange thing is the old XP2600 CPU doesnt work anymore.. Also do I need a new h/sink - currently using a thermoengine and probably wont be overclocking....
Any suggestions greatfully received!!
