Set the RAM voltage and timings manually to what they say on the side of the stick.
But just set the freq to 1333MHz as you currently have it and not 1600MHz as that shouldn't be selectable.
Reset the cmos, turn power if at the wall and remove the battery for a minute. Turn back on and load optimized settings in bios again.
if so should i reset and leave it after that?
