I am considering upgrading my PC. Spec is currently i7 920 @3.2ghz, Gigabyte UD5, 24GB Corsair Vengence, 128GB SSD, 2TB HDD, GTX580 GPU.
I have a budget of around £1200 (I'm flexible, but no silly stuff, i would rather it lower than higher) and will use the PC predominantly for Gaming and Streaming Video, but I do also use it for work (mine current PC is more than enough for that though). The PC should also have a CPU & Mobo shelf life of 3 years minimum before I need to upgrade again.
I will be passing on my PC to my 13 year old so while I could reuse the DDR3 (I have some patriot stuff to replace it with and the HDD and SSD. I will need a new case (Corsair 600T in white) and PSU etc....I would prefer a liquid cooler similar to the Corsair H50 I have currently, rather than huge air coolers, but obviously an improved one.
So it's been a while since I have looked at PC stuff and I don't know my ivybridge from my sandybridges etc...so advice and specs are most welcome...
Thanks...Castiel.
Thanks...Castiel.
). If you want to get a new close loop liquid cooling set i suppose you could get the Corsair H60 or H100 but to be honest the H60 is enough for most people, it depends on your CPU of choice and the clock your aiming at. You might even want to have a go at a custom loop, with a bit of thought and £1200 you can go a long way!
