- 17 Aug 2012
The only difference to you in the two options is the quality of the system your son gets.
While the i7 920 is certainly "not as good" as the new Intel mid to high-end CPUs, the thing is a high overclock i7 920 would still have no problem pushing 60fps (the higher most standard 60Hz monitors would output) in most games, bar CPU demanding games like mmos, RTS games like Total Wars or Starcraft with ridiculous numbers of dynamic units or players).So you are saying that the i7 920 is as good as all the current CPUs out there, that haswell will be pointless as well..that USB3, SATA3, and whatever other improvements over my old x58 are also not worth it and I should buy a £600 midrange PC for my boy and £500 on GPUs for myself...so effectively spending £1100 anyway?
I would go with a good 1155 over a cheap 2011.
You will also save yourself a lot of money that way too!Do you do much video encoding type work Castiel? Or would gaming be the main use?
Id be inclined to go with a Z77 board and an i5 3570k. Primarily a gamer myself and i recently switched out one of my X58 systems, (4.2ghz i7 920) for the cpu and motherboard in sig. Gaming performance is virtually the same.
Ive thought about going for an i7 3770k, but tbh it would only be beneficial in multi gpu situations at resolutions above 1080 res.
I see that youve already opted for x2 7950's. Will theese be used in xfire on one system, (as you already have a gtx 580). Due to it's onboard 3gb ram count, the 7950 copes better at high res than the nvidia equivalents such as the 670. A single 7950 with a bit of an overclock will handle 1440 fine, the gains with a cpu such as the 3770k really tend to show up with multiple gpu's in triple screen monitor setups.
That case id go for the 3770k then.
Sabretooth is indeed a cracking looking board, excellent PCIe slot spacing. Which is a must have with xfire/sli. I tend to stick with asus boards myself due to familiarity with their bios setup.
I had looked at s2011, but was put off by the price more than anything.
