Caporegime
- 18 Sep 2009
- Dormanstown.
3770k is better than the 3820.
3570k will pretty much mirror the 3770k in gaming (Obviously there's some situations where this isn't the case)
But a 3570k in some cases would be less than your current i7 in heavily threaded situations.
3770k isn't cost effective for gaming over a 3570k though.
Kitkat's parts are fine, not sure on the coolers however, I have a 7950 Crossfire myself, end performance is stupidly good.
What would be the end PC your son got if you bought Kitkats parts?
EDIT : Although, I can't treat it as upgrading your PC, CPU wise the upgrade I'd do would be a second hand gulftown at 250, which when going 100% would outrun everything bar the 39XX stuff on socket 2011, then probably with a second hand GTX580 and almost double your GPU performance.
Much higher CPU upgrade percentage wise than a 3770k/3820 ever would be when going maxed out, and a stock GTX580 SLI isn't miles away from a stock 7950 Crossfire.
When the 7950 launched it wasn't miles faster than the GTX580.
But don't take that as a suggestion, that's just purely what I'd do as a cost effective upgrade route on your own system, and is certainly not the advise that you're after as it doesn't at all suit your situation.
