Hi OCuK. I come looking for your help yet again!
I stream to YouTube using OBS at 1080p and upload gaming video's four times a week. I use Audacity, Movavi and Camtasia as editing software. I also use Reaper as my audio processor.
For input, I use an Elgato HD60, a Blue Yeti microphone and a Logitech C920 webcam.
I'm looking to build a new machine, as my current i5 set-up struggles.
I don't need monitors, or a keyboard / mouse or an OS as I have those recently purchased anyway. So, I'm effectively looking for a base unit.
Budget is £1,500 and if needed, I can reuse the DVD-writer and 125Gb Kingston SSD from my old PC if it saves enough cost to get a worthwhile upgrade. I'd like to include a dedicated sound card if anyone thinks it will be beneficial and take load away from the CPU for audio processing, but my Mic is USB.
AMD seems the way to go at the moment, but I'm open to suggestions. So, OCuK, work your magic! I very much appreciate it!!
Thanks
amx
Thanks
amx
